Translation > Rejected Feature Handling
  • September 25, 2018
  • 9 replies
  • 1019 views
A colleague upgraded another software on our FME server and somehow changed the setting on 100s of workspaces to Translation: Rejected Feature Handling:Continue Translation but they should be Terminate Translation... anyone able to batch change them back? I have tried - changed the default in FME Options, rebooting.... Thanks!
This was on FME Desktop 2017
Best answer by hollyatsafe
Hi @cmcnamara
As discussed changing the default in FME Options will only apply to newly created workspaces. I spoke to a colleague after our conversation and she recommended doing a search and replace on the workspace files themselves from within a text editor.
The option would be in a line like:
#! TERMINATE_REJECTED=“NO”
so just change it to:
#! TERMINATE_REJECTED=“YES”
My next thought is... would an upgrade to 2018 help?
danilo_fme
Forum|alt.badge.img+50
Hi @cmcnamara
You can change the option on Navigator to Continue Translation:
Thanks,
Danilo
Hi @cmcnamara
danilo_fme wrote:
Hi @cmcnamara
Thanks,
Danilo
Thanks! I've got 100 workspaces, so I'm hoping not to have to manually update them all - they all changed to Continue and I want Terminate.
hollyatsafe wrote:
Hi @cmcnamara
In the tcl file?
It didn't.
cmcnamara wrote:
In the tcl file?
Hi @cmcnamara
No, you can open up the .fmw itself in a text editor.
  • September 26, 2018
hollyatsafe wrote:
Hi @cmcnamara
I'll also add that there are utilities out there that can do the search-replace as a batch operation on the contents of a whole directory at once. That way you don't have to open each and every .fmw file in an editor, do the changes manually and save. Might be helpful here.
This saved the day! Thank you! @david_r
