Use date user published parameters in SQLCreator
  • Mar 6, 2019 3:14 PM UTC
  • 172 views
tsirkuse
Forum|alt.badge.img+4
Hello,
I am reading my oracle non spatial database with an SQL query containing couple of dates. When inputting the dates directly in the query, there is no problem and it runs smoothly.
I would like to make user parameters from these dates. So I have created published user parameters choosing 'date' as type.
I then try to use the parameter in my SQL query (where clause) but I get a type error over and over. I have tried couple of different notations but it doesn't seem to work...
This works (without parameters)
AUTO_START_DATE <= TO_DATE('15/12/2019', 'DD/MM/YYYY')
Then I tried several variation to use :
$(START_DATE)
but I can't seem to find the right syntax.
Thank you
Best answer by erik_jan
Did you try AUTO_START_DATE <= TO_DATE('$(START_DATE)', 'YYYY-MM-DD')
erik_jan
Forum|alt.badge.img+26
  • Mar 6, 2019 3:20 PM UTC
  • Mar 6, 2019 3:22 PM UTC
The DATE-type parameter returns an "FME date" string, so you should use
to_char('$(START_DATE)', 'YYYYMMDD')
Notice the form YYYYMMDD.
Forum|alt.badge.img+54
  • Mar 6, 2019 3:23 PM UTC
The parameter is stored in FME format, i think you will need to use something like
AUTO_START_DATE <= TO_DATE($(START_DATE), 'YYYYMMDD')
erik_jan
  • Mar 6, 2019 5:00 PM UTC
Did some testing and @egomm is right.
It should be:
AUTO_START_DATE <= TO_DATE('$(START_DATE)', 'YYYYMMDD')
