Copying folder structure only with FileCopy ?
  • Aug 5, 2025 6:14 AM UTC
  • 166 views
tsirkuse
Forum|alt.badge.img+4
Hello,
I am looking for additional insights on File Copy
  • Is it possible to copy folder structure without copying files inside ? How do I set the writer ?
  • What is the filecopy_type parameter ? and what are it’s possible values ? The parameter exists on the writer but I can’t find any information.
Thank you
Best answer by geomancer
You can also use SystemCaller, and invoke xcopy (of robocopy) there.
With xcopy use something like
xcopy "c:\temp\MyOriginalFolder\" "c:\temp\MyCopyFolder\" /t/e
Use /t to copy only the folder structure, not the files
Use /e to include empty folders
  • Aug 5, 2025 2:45 PM UTC
Hi ​@tsirkuse ,
I don't think that there is any option to copy only folder structure with File Copy writer unfortunately.
However, Python scripting might help you. For example, this script defined in a PythonCaller creates the same folder structure as the subfolders of “_source_folder” under “_destination_folder”.
import fme
import fmeobjects, os
class DirectoryCopier(object):
def __init__(self):
pass
def input(self, feature: fmeobjects.FMEFeature):
def copy_dirs(src, dst):
with os.scandir(src) as iter:
for entry in iter:
if os.path.isdir(entry.path):
dir = os.path.join(dst, entry.name)
os.makedirs(dir)
copy_dirs(entry.path, dir)
src = feature.getAttribute('_source_folder')
dst = feature.getAttribute('_destination_folder')
copy_dirs(src, dst)
self.pyoutput(feature)
def has_support_for(self, support_type: int):
return support_type == fmeobjects.FME_SUPPORT_FEATURE_TABLE_SHIM
def process_group(self):
pass
def close(self):
pass
hkingsbury
Forum|alt.badge.img+73
  • Aug 6, 2025 9:44 PM UTC
You could use the Directory and File Pathnames reader to read only the folders, then write a blank text file to the lowest folders (to create all the higher folders in the tree), then go through a delete the blank text files.
In my view, ​the approach @takashi outlined would be what I’d choose unless overarching policies blocked the use of Python
geomancer
Forum|alt.badge.img+71
  • Aug 7, 2025 5:35 AM UTC
