Transform a 3D polyline to a normal polyline
  • April 1, 2015
  • 477 views
ahmad_saleh
Hello All,
I couldn’t figure out how to transform a 3D polyline to a normal polyline in AutoCAD using FME, I have tried the 2d forcer but this command only removes the Z value  without changing the type of line in AutoCAD, please have a look at the following screenshots.
The input Autocad file
the Output "Result file"
I need the result file to be like the following screen shot is it possible to do in FME ?
Many thanks,
Ahmad
Best answer by david_r
try an AttributeCreator:
David
endest
  • April 2, 2015
Set the value of "autocad_original_entity_type" attribute to "autocad_lwpolyline"
ahmad_saleh
  • April 2, 2015
Hi Endest,
Could you please elaborate more, how to do this?
And if it’s possible please provide a screenshot
Thanks,
Ahmad
  • April 2, 2015
David
ahmad_saleh
  • April 2, 2015
Many thanks David and Endest,
It worked fine now, the 3D PloyLines was transform to polyline using AttributeCreator
Best Regards,
Ahmad
