Tabulate Intersection?
Does anybody know how to replicate this with FME? http://pro.arcgis.com/en/pro-app/tool-reference/analysis/tabulate-intersection.htm
Best answer by stalknecht
Hello @richardtriesfme,
You can use a Clipper and an AreaCalculator to do this in FME.
If you have some test data then I can give you an example. (please provide the FME version you use also)
Best regards,
Wilko Stalknecht
stalknecht
Forum|alt.badge.img+21
  • August 1, 2017
Best regards,
Wilko Stalknecht
danilo_fme
Forum|alt.badge.img+51
  • August 1, 2017
Hi @richardtriesfme, the @stalknecht gave you the correct names of transformers that you can use: Clipper and AreaCalculator.
If your source data is a raster and you would like to get the quantity of pixel: blue, green and red you can use the transformer RasterCellCoercer to extract vectors from raster and calculate the percentagem.
Thanks,
Danilo
