How can I restart a row counter in FME at the beginning of each year?
  • Sep 22, 2025 2:43 PM UTC
  • 131 views
farzanehahmadi
Hello everyone
I have a dataset with a year attribute (e.g., 2025, 2026). I want to generate a rowid that starts at 1 for each new year and increments sequentially.
Example:
  • For 2025 → rowid should be 1, 2, 3 …
  • For 2026 → rowid should reset back to 1, 2, 3 …
I then want to concatenate the last two digits of the year with the padded rowid to create a WorkOrderID like:
  • 250001, 250002 …
  • 260001, 260002 …
Which FME transformers or workflow should I use to reset the counter per year?
Best answer by ebygomm
You can do this with a counter, just set the Count Domain to the attribute containing the year
Then something like this to create your work order id
Forum|alt.badge.img+54
  • Sep 22, 2025 2:48 PM UTC
farzanehahmadi
Hi ​@ebygomm , thank you so much, it worked.
