swap value with criteria
  • Apr 7, 2020 3:29 PM UTC
  • 26 views
Hello
I can't find a simple solution for the scenario below:
if you look on the diagramm, I want to put my uuid value with fk_type=1 in the fk_parent_uuid field when fk_type=2
but I make a big package of spaghetti instead
Would you have a brilliant idea ?
thanks
fmelizard
Forum|alt.badge.img+22
  • Apr 7, 2020 7:16 PM UTC
Hi @jerome If you need the attribute from the previous record then Enable Adjacent Feature Attributes in the AttributeManager.
If you need to set fk_parent_uuid to the value of uuid where fk_type_ = 1 - for all following records where fk_type = 2, then use a VariableSetter and VariableRetriever. You'll need a Tester on fk_type_ - warning! be sure to set the Advanced parameter Preserve Feature Order to 'Across Output Ports'
