StringCaseChanger test for sting case first
  • Sep 23, 2021 5:25 PM UTC
  • 111 views
dos_gis
Forum|alt.badge.img+3
Hi, I'm using StringCaseChanger but I'd first like to test if a attribute string is all caps. I'm using tester with Regex [A-Z\\s]+ and Case Sensitive mode but I'm not getting the expected results. Any ideas on how I can tester for attributes with all caps? These are paragraphs that might contain numbers and other symbols as well.
@dos_gis​ Do you have a small example of a couple of strings that you're trying to test? If the string is already uppercase, then StringCaseChanger should just run it's course - assuming you're trying to make everything uppercase
dos_gis
  • Sep 23, 2021 7:58 PM UTC
Hi Mark, The data is a mix of uppercase and sentence case. I'd like to test for uppercase then use StringCaseChanger on that selection only - changing uppercase to title case.
  • Sep 24, 2021 6:43 AM UTC
The most robust way to do it is perhaps to create a copy of the original string and run it through the StringCaseChanger set to UPPER case. Then compare the original and the copy of the string; if identical, it was already all upper case.
