Split intersected polygons into equal parts
  • Feb 27, 2020 11:38 AM UTC
  • 162 views
ronan
Hello,
here is my problem : I create a buffer from input points data. When the distance between 2 points is small, the buffers overlap. I would like to split the 2 overlapped buffers into 2 parts with the same area. Each polygon retrieve the attribute values of the associated point.
I don't find any satsfaying solution. Is there a known issue?
Forum|alt.badge.img+54
  • Feb 27, 2020 11:50 AM UTC
Have you tried putting your points into a VornoiDiagrammer instead?
ronan
  • Feb 27, 2020 12:03 PM UTC
Thanks a lot :-). I was trying complex spatial process to split polygon after the buffer, but VoronoiDiagrammer is simple and provide the good result.
