Spikes in 3D view
nogger
Another one from my daily work:
Is there any chance to find “spikes” in elevation to avoid situations like this in 3d view? I already found that there is spike remover but my job is to only find them.
Red lines are bridges and they should look like a little bit smoother :)
Attribute which they are based on is “F_ELEV” and “T_ELEV”
Please help me with identifying such situation using FME.
Shapefile with this situation:
liamfez
Forum|alt.badge.img+43
  • May 22, 2024
You could still utilize the SpikeRemover, and just take the points from the Removed port if all you want are points of where spikes are.
nogger
  • May 22, 2024
@liamfez I think in my case the problem is that my data are in 2D. The only attributes I can rely on are “F_ELEV” and “T_ELEV”.
