Spatial relations between points and lines
  • September 7, 2015
  • 42 views
I have set with unique points and non unique lines. All endpoints of all lines are in the point set. When I use SpatialRelator (lines are requestors and points are suppliers) with TOUCHES test, I'm getting more related candidates than 2. How is this possible?
  • September 7, 2015
Hi
Could it be that some lines are intersecting start/endpoints of other lines?
You may want to convert your lines to start/endpoints (CoordinateExtractor with 0 and -1 indexes, then VertexCreator) first, if you need to avoid this scenario. You might also want to consider using the NeighborFinder if you need to introduce a small tolerance.
David
  • September 8, 2015
David,
Problem was (of course) on my side. Not so unique points even after thousands checks...
Thanks anyway!
