Spatial Filter polygon cut by another
Hello,
I try to count points within polygons. The problem is that my selection of points does not take into account all the polygons but is cut at the intersection of the two polygons. I tried everything in the options of the spatial Filter but I can't find the solution.
In the screenshot, I'm testing attribute 60
Thank you for your help
Forum|alt.badge.img+41
  • March 26, 2020
If you have multiple polygons that overlap then you look at using a spatial relator or a point on area overlayer. These will both allow you to build a list against each point detailing which polygon(s) it overlaps. You can then explode the list to get a point per polygon.
  • March 26, 2020
Thank you @ebygomm but I need to sum a field Pop from the points and now I have two list , one for the points and one for the areas. How can I combine them without a common field?
