Simple Spatial join
hi experts
I am trying to do a simple spatial join or a point on line overlay . I need to pick up the line segment that the point intersects or touches . As the point is not exactly on the line , I have a tolerance setting on the Point on Line Overlay transformer . But the full line segment is not picked up and only one part is picked up as the line is split at the point . Is there a way around this or another transformer you can recommend
Thanks for your help
  • March 10, 2016
HI @reshu, the NeighborFinder might help you.
  • March 11, 2016
Thanks takashi
will give it a go . is there a traansformer that does a join by matching attributes and a spatial join ?
pratap
Forum|alt.badge.img+11
  • March 11, 2016
FeatureMerger is the transformer for merging based on attribute
Pratap
  • March 11, 2016
reshu wrote:
Thanks takashi
Maybe using "Group By" parameter in a spatial transformer can resolve your question.
gio
Forum|alt.badge.img+15
  • March 11, 2016
You can also use a spatial filter or relator (with tester).
Then you have spatial selection without chopping the line. As there is no tolerance setting for that you might have to use a bufferere prior to that.
A neighbourfinder is of course valid as the searchradius would be functioning as tolerance.
All these can be done in group by mode.
Featuremerging would negate any spatial tolerance btw.
mark2atsafe
Forum|alt.badge.img+48
  • March 11, 2016
Yes, my first thought was a Bufferer/SpatialFilter combination. We have an example of that as an exercise in our Desktop training course
mywarpedmind
Participant
  • Participant
  • August 22, 2016
I've tried SpatialRelator. The Requestor attribute columns are present and populated, and new columns are added for the Supplier attributes, but they're all <missing>
itay
Forum|alt.badge.img+17
  • August 22, 2016
have a look at the list generated by the SpatialRelator.
mywarpedmind
Participant
  • Participant
  • August 22, 2016
The list? Sure One image shows the output table. I threw in an inset of the SpatialRelator's parameters, but I left the default values. I also tried the AreaOnAreaOverlayer but the translation seems to stall at this line.
Thanks
itay
  • August 22, 2016
the list and its elements will show in the feature information window of the data inspector and not in the table view.
