Select tables to read from a SDE Geodatabase
  • May 17, 2022 2:46 AM UTC
  • 205 views
Forum|alt.badge.img+3
I want the user to be able to select the tables to be read from a geodatabase. I added the reader using the single merged feature type. This gives me a list of tables for them to choose from. What I want to happen is depending on which tables are selected, it will output to a schema mapper which reads the tables and writes to a geodatabase. So, I was thinking I would want a tester but the tester doesn't have the ability to show the tables. Anyone have any idea of how this can be done?
j.botterill
Forum|alt.badge.img+69
  • May 17, 2022 3:15 AM UTC
After reading in all the feature types (ideally using a Feature Reader transformer), you could potentially use a FeatureTypeFilter or you may want to read up about dynamic workspacesimage
Forum|alt.badge.img+54
  • May 17, 2022 8:04 AM UTC
As above, if you use a FeatureReader you can use the selected feature types as features to read. If you read the schemas as well you can then write to a gdb dynamically by sending the schema and the features to the writer
@chris28​ If you include the source table name in the SchemaMapper, you can use this as a SchemaMapper filter. You should then be able to use a single schema mapping table. In this case, you won't need to filter in the workspace. You could combine this with a dynamic writer which should really simplify your workspace.
  • May 18, 2022 1:18 PM UTC
Thanks for all the ideas. I ended up using the FeatureReader and then the SchemaMapper which then wrote out to the geodatabase and it worked perfectly!
