Scaler won't grant value from other attribute column as Scale factor.
  • Feb 16, 2018 1:02 PM UTC
  • 40 views
rimonku
I am trying to scale a number of text (containing map legends) as such ; with the number of generated x coordinates within a specified bounding area the texts will be scaled up/down relatively.
For example, if I have 5 'x' coordinates generated in a map area , the scale factors in X: ang Y: will be 5. I have a atrribute where it saves the nuber of generated 'x' coordinates and i would like to read the valus from there as X: and Y: scale factor in Scaler. But when I try to read the column values in Scaler transformer, it rejects the tranlation. Any idea how to solve the problen ?
  • Feb 16, 2018 1:06 PM UTC
You have to merge the incoming features first, so that you have a single feature containing both the geometry to scale and the X-factor.
The easiest is to use a FeatureMerger with some artificial, but identical value on both sides, e.g.
Tip for future posts: Please include any relevant error messages from the FME log window :-)
