Replaceing output value to new dataframe
  • Feb 3, 2020 10:39 PM UTC
  • 98 views
Hi there,
I use Python caller to run Python script in FME. Python caller reads the data and generates a new data frame (with more attributes) after performing calculations. Now I want to output the new data frame and do not display the old data (that is feeding as input to Python Caller). I am not sure how to do that. Any help would be really appreciated.
  • Feb 4, 2020 8:43 AM UTC
Are you just removing columns and creating new ones so 10 records in and 10 out, or creating more or less records, so 10 records in and 5 out?
It's more record coming in and less record going out
  • Feb 5, 2020 9:41 AM UTC
This is when you use the self to store that values you want to create in the close section as the init / self values are global variables.
The code below is the same as a group by with a sum total of the value
import fmeobjects
import fme
class FeatureProcessor(object):
    def __init__(self):
# create my store of values
        self.featureStore = {}
    def input(self,feature):
        Group = feature.getAttribute("ColA")
        Value = feature.getAttribute("ColB")
# if the value exists in the store then add the value otherwise create a new value in the store
        try:
            CurrentValue = self.featureStore[Group]
            self.featureStore[Group] = CurrentValue + Value
        except KeyError:
    def close(self):
# loop through the store and create the new features
        for group, value in self.featureStore.items():
            newFeature = fmeobjects.FMEFeature()
            newFeature.setAttribute("NewColA", group)
            newFeature.setAttribute("NewColB", value )
            self.pyoutput(newFeature)
Also remember you will need to show and hide the correct attributes.
