Replace function in SQLExecutor? Or any alternative?
Hello all,
I'm trying to update an Access table of mine using generated GUIDs, lets say I have the following:
Table_one
PARENT_GUID,FIELD_GUID
ABC123-EFT1,TEST23
ABC123-EFT1,TEST24
ABC123-EFT2,TEST23
ABC123-EFT2,TEST25
Also:
Table_two
PARENT_GUID,MEMO_FILLED_WITH_GUIDS
ABC123-EFT1,#IF##AND##CONDITION#{TEST23}ISNULL#ENDCONDITION##THEN##DO#{TEST24}ISMANDATORY
ABC123-EFT2,#IF##AND##CONDITION#{TEST23}ISNULL#ENDCONDITION##THEN##DO#{TEST25}ISMANDATORY
Now, due to some reasons, as you can see the FIELD_GUID is non-unique. I want to make it unique, and replace the FIELD_GUIDs with freshly replaced ones. However, seeing Table_two.MEMO_FILLED_WITH_GUIDS is a memo field filled with guids, I'd thought of using the replace function, within a SQLExecutor, like this:
UPDATE Table_two SET MEMO_FILLED_WITH_GUIDS= replace(MEMO_FILLED_WITH_GUIDS, @Value(FIELD_GUID, @Value(NEW_GUID_GENERATED)) WHERE PARENT_GUID = @Value(PARENT_GUID)
Where NEW_GUID_GENERATED is a GUID generated using FME.
However, this results in the following:
ERROR |MS Access Reader: Query failed. (-2147217900) Undefined function 'replace' in expression.'
Is there a way I can still use replace? Or is there a FME transformer which I can use to replace a value in a string based on another column, and use the PARENT_GUID in a where kinda clause?
Thanks in advance!
Best answer by takashi
I'm not sure why the replace function cannot be used in the SQLExecutor, but this way could be a workaround.
1) Use an SQLExecutor to merge MEMO_FILLED_WITH_GUIDS to the initiator features.
SQL Statement:
SELECT MEMO_FILLED_WITH_GUIDS
FROM Table_two WHERE PARENT_GUID = '@Value(PARENT_GUID)'
Attributes to Expose: MEMO_FILLED_WITH_GUIDS
Combine Attributes: Keep Initiator (or Result) Attributes if Conflict
Note: Maybe the Joiner can be also used instead of the SQLExecutor.
2) Send Result features into a StringReplacer transformer to replace FIELD_GUID with NEW_GUID_GENERATED.
Attributes: MEMO_FILLED_WITH_GUIDS
Text to Match: FIELD_GUID (Attribute Value)
Replacement Text: NEW_GUID_GENERATED (Attribute Value)
3) Send Output features into 2nd SQLExecutor
SQL Statement:
UPDATE Table_two
SET MEMO_FILLED_WITH_GUIDS = '@Value(MEMO_FILLED_WITH_GUIDS)'
Hope this helps,
Takashi
  • May 18, 2014
SQL Statement:
SQL Statement:
UPDATE Table_two
Hope this helps,
Takashi
  • May 19, 2014
Hey Takashi,
That would nearly work! The thing is, MEMO_FILLED_WITH _GUIDS could theoretically contain an infinite amount of unique GUIDs (Well, up to max memo field length / GUID length, but that doesn't matter).
For the example above, I'd have to run the Workbench twice, seeing it once would replace the value:
to:
#IF##AND##CONDITION#{N3W-TEST23}ISNULL#ENDCONDITION##THEN##DO#{TEST25}ISMANDATORY
but in the same run:
#IF##AND##CONDITION#{TEST23}ISNULL#ENDCONDITION##THEN##DO#{N3W-TEST25}ISMANDATORY
And on second run:
to:
#IF##AND##CONDITION#{N3W-TEST23}ISNULL#ENDCONDITION##THEN##DO#{N3W-TEST25}ISMANDATORY
So the best way would be a replace function, to just replace the string that needs replacing, instead of the whole attributevalue... But how...
  • May 19, 2014
rather than using the FME Replace function, you should probably be using the MS Access Replace() function in stead.
See the documentation here (http://www.techonthenet.com/access/functions/string/replace.php).
David
  • May 19, 2014
Hey David,
I'm afraid that is the Replace() function from Acces ;)
However, Access doesn't support batch query running, and I found out Replace() function isn't usable anywhere outside of Access... And I don't want to run 1200 queries (Rows in Table_one) by hand.
I've used a workaround for now, exporting Table_two to SQLite, then using Replace(), then importing it back to Access.
To be honest, I'll be happy when I finally won't have to use Access anymore.
For me this is solved for now, if anyone knows a better solution, that would be awesome.
Thanks to you both!
  • May 19, 2014
It might be that your Access database is too old to support the Replace function in the API calls.
There is a nice workaround here (http://www.access-programmers.co.uk/forums/showthread.php?t=142513). Might be worth a try.
David
