read all files in directory
  • Apr 30, 2020 3:24 PM UTC
  • 163 views
Hi ,
I need to do a conversion between 2 formats with many files in several directories ,how can I define that output directory =input directory
Forum|alt.badge.img+54
  • Apr 30, 2020 3:30 PM UTC
What formats are you converting between? The answer may differ slightly depending on whether you are reading file based or folder based datasets
  • Apr 30, 2020 4:38 PM UTC
3ds to collada
mark2atsafe
Forum|alt.badge.img+59
This will probably help: https://knowledge.safe.com/questions/29907/write-the-result-on-the-same-folder-as-the-input.html
What you need to do is find the source directory (it is stored as an "FME Attribute" called "fme_dataset"). Then you use that in a fanout on the output. I'm not totally sure about collada. You may follow the instructions there to set the feature type name; otherwise it might need a fanout on the writer (look for the fanout setting in the Navigator window)
