Read AEC Objects (Geometries and Attributes) in FME
  • March 13, 2025
  • 16 views
g_tz
I am working on feature and attribute extraction from an AutoCAD Architectural file, namely the extraction of room polygons and their attributes from AEC blocks that represent rooms. I have tried the Civil 3D reader and the reader actually sees the layer with the room AEC blocks and it shows me the available attributes correctly, alas the reader does not return any features. There are no errors, only a lot of warnings about attribute renaming because of scpecial characters.
Has anyone ever succeeded in reading AEC block features and attributes? If so, how did you do it?
emmaatsafe
Forum|alt.badge.img+7
  • March 14, 2025
Hi ​@g_tz
Would you be able to provide screenshot(s) of how the reader is set up and the log file containing all the warnings? If you're comfortable sharing the input file you're trying to read, that would be helpful as well!
Emma
