Raster Palette Ranges
  • February 6, 2017
  • 7 replies
  • 187 views
I am trying to create a colour palette for a single band raster, where the cell values range from the -1 to 1. Is it possible to create a colour palette where the resultant RGB colour are referenced to a cell value via a range than the exact matching of a single value?
For example how could the range values and colours listed below be used to visualise a raster?
class_range,r,g,b
[-1.0]..[-0.6],252,141,89
[-0.2]..[0.2],255,255,191
[0.6]..[1.0],145,191,219
Is this possible? If so can anyone provide some advice?
I am using FME Desktop 2015.1.
Regards,
Rob
Forum|alt.badge.img+7
Hi @rob14
I think you can solve this issue with a basic TestFilter and some AttributeCreators or combine everything in an AttributeManager with conditional values.
  • February 6, 2017
Hi @rob14, how many colors do you need to define? If the number of colors is not so large, I would transform the source raster into RGB color raster with the RasterExpressionEvaluator and then generate a palette with the RasterPaletteGenerator.
[Addition] e.g. if you need only three colors:
  • February 6, 2017
Hi @takashi and @jeroenstiers
Thanks you both for the workflows whci you sent, these are the type of thing which I was interested to know. As I was unaware as to the method to create a range clause for a raster value.
At present I do not know the number of classes which I will potemntially require, therefore these alternate methods will provide me with some options.
Regards,
Rob
  • February 6, 2017
If you have created an external table which defines the mapping rules between value ranges and palette entries, e.g. "resource.csv":
lower,upper,entry,R,G,B
-1.0,-0.6,0,100,240,240
-0.6,-0.2,1,140,180,220
-0.2,0.2,2,180,100,180
0.2,0.6,3,220,180,140
0.6,1.1,4,240,240,100
this workflow might work for you.
SQL Query:
select a.*, b.entry
from raster as a inner join resource as b
on b.lower <= a.value and a.value < b.upper
Palette: the transformers within the lower bookmark create this text as an attribute called '_palette'.
RGB24
0 100,240,240
1 140,180,220
2 180,100,180
3 220,180,140
4 240,240,100
Regarding palette definition, see the help doc on the RasterPaletteExtractor transformer.
Hope this helps.
  • February 7, 2017
Hi @takashi
Thanks for the revised workflow, I am sure that I will need to implement more that 2 or 3 ranges. Therefore your new workflow will provide greater flexibility. I am in the process of working on the stages before the visualisation. I will let you know how I get on with the visualisation element.
Regards,
Rob
  • February 8, 2017
Reminded me a similar question. This Q&A; could also be a hint.
Classify raster data by breakpoints
  • February 8, 2017
Hi @takashi,
Thanks for the additional link to the breakpoints post.
This is another interesting way to achieve the visualisation, and exactly what I was after.
I spent some time last night working on and understanding the nested if statements, and have devised my breakpoints (about 12). I used a graduation of only r values (0-225) to visualise but having seen this other example I think that the 'reclassing' example with additional palette creation will allow of greater visual clarity.
In addition/out of interest; I presume that you could also use this technique to actually reclass a raster using user defined ranges if you wanted to? And then subsequently split out into the revised classes? I only ask as I have a floating point raster which I am going to have to do this for i.e. something similar to NDVI splitting.
Regards,
Rob
