Raster Mosaicker | Merging multiple tiff files
  • February 11, 2014
  • 62 views
Hello
I have 100+ tiff files with the correponding xml, tfw, and tab files that I would like to combine for use in GIS. I thought I can do this with rastermosaicker in FME but I have been unsuccessful. Can anyone help?
Thanks
fmelizard
Forum|alt.badge.img+20
  • February 11, 2014
can you provide more info about your trial? maybe log file screen shots? or messages?
  • February 11, 2014
Hi
So all I did is add a reader that contains all of the TIFF files and then have that into a rastermosiacker. however even just loading in the reader doesnt work. the folder contains xml, tfw, tab and tiff files that create the raster. So I guess my first problem is how to load in the reader.
fmelizard
  • February 11, 2014
The TIFF reader should be able to read only the .tiff or .tif files, you can specify in a folder and use a filer *.tff to avoid the other file foprmats on the flder. see http://docs.safe.com/fme/html/FME_Workbench/Default.htm#Merging_Similar_Datasets.htm
