Polygon to Multipolygon (FME 2018.1)
  • Jun 1, 2020 9:42 AM UTC
  • 554 views
Hi. I have seen a thread in which they explain that for converting from polygon to multipolygon you only have to choose the geommetry type in the writer parammeters (on FME2019). The thing is that I can't see that option. Is multipolygon not available on FME 2018.1? If not, how can I convert a polygon to a multipolygon? Thanks!
Best answer by oscard
Before the Writer, use an Aggregator to convert the features into Multipolygons.
As a "Group By" you must pick a unique identifier.
oscard
Forum|alt.badge.img+23
  • Jun 1, 2020 10:27 AM UTC
Thanks, it worked!
