Point from Oracle shows at the wrong location in Visual Preview with a Background Map from a WMS
  • Aug 17, 2022 9:41 AM UTC
  • 40 views
arnovananrooij
Forum|alt.badge.img+5
FME seems to display a single point from Oracle at the wrong location. I have a simple workspace with a SQLCreator with the following statement:
select SDO_GEOMETRY('POINT(163170.864 501575.234)',28992) from dual
I would like see the location in the visual preview so I have a background map which is a WMS in the same coordinate system: http://www.openbasiskaart.nl/mapcache/?  with the layers {Openbasiskaart}|{osm}. The point is shown at the wrong location somewhere in the middle of the sea. When I add a bufferer with 200 meters it is shown at the correct location. Is this a bug?
I have attached my workspace (FME 2021.1.3)
@arnovananrooij​ Thanks for including the little example workspace. I couldn't reproduce this in FME 2021.2 or FME 2022.1. The output from the SQLCreator is show below:
