Archived
Add support for GeoBuf
Related products:Integrations
  • October 17, 2017
  • 6 views
danilo_fme
  • danilo_fme
    danilo_fme
fmelizard
https://github.com/mapbox/geobuf
Geobuf is a compact binary encoding for geographic data.
Geobuf provides lossless compression of GeoJSON data into protocol buffers. Advantages over using GeoJSON alone:
  • Very compact: typically makes GeoJSON 6-8 times smaller.
  • 2-2.5x smaller even when comparing gzipped sizes. - Very fast encoding and decoding — even faster than native JSON parse/stringify.
  • Can accommodate any GeoJSON data, including extensions with arbitrary properties.
The encoding format also potentially allows:
  • Easy incremental parsing — get features out as you read them, without the need to build in-memory representation of the whole data.
  • Partial reads — read only the parts you actually need, skipping the rest.
Think of this as an attempt to design a simple, modern Shapefile successor that works seamlessly with GeoJSON. Unlike Mapbox Vector Tiles, it aims for lossless compression of datasets — without tiling, projecting coordinates, flattening geometries or stripping properties.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
darkspatiallord
did this get done
