OS vector map and FME
  • January 9, 2013
  • 5 replies
  • 67 views
I'm trying to take the OS vector map local, apply an OS style sheet (I have xml and xsl files) and then output it to MapInfo tabs using FME, and I'mhaving absolutly no luck in the slightest.
I was hoping that someone here has already done this, or something similar and would be willing to share their experiances with me.
(I'm very new to GIS, having only started at the end of last year, and we've only just gotten FME installed last week, so even the experianced GIS people have only just started using it)
flavio
  • January 9, 2013
Hi Rhodri
This is not that straight forward ... What you can use is the "MapInfoStyler" and some lookups - AttributeValueMapper (i.e. depending on the OS data attribues). And you will be limited to what MapInfo gives you for styling ... If you are lucky someone has done that before ...
davideagle
Forum|alt.badge.img+21
  • January 9, 2013
I spent a little time outlining some of the styling options that you can use when working with MapInfo in this webinar on YouTube below. I'd probably suggest a combination of the SchemaMapper and the MapInfoStyler. Certainly the AttributeValeMapper will help though a slight downside is that you end up hard coding the style information into your workspace, with the SchemaMapper you can store your style details in say XLS and then adapt the style or make variations stored in XLS without a need to change the FME workspace.
To go down the style sheet route you may need to look to read the XML, parse the style out by FeatureCode and then join it onto each feature. I suspect given the complexity of VML you may find this approach quite complex.
Feel free to drop me a note with a bit more detail off the group once you've taken a look at YouTube, at david.eagle@1spatial.com.
davideagle
  • January 9, 2013
I spent a little time outlining some of the styling options that you can use when working with MapInfo in this webinar. I'd probably suggest a combination of the SchemaMapper and the MapInfoStyler. Certainly the AttributeValeMapper will help though a slight downside is that you end up hard coding the style information into your workspace, with the SchemaMapper you can store your style details in say XLS and then adapt the style or make variations stored in XLS without a need to change the FME workspace:
http://www.youtube.com/watch?v=1c_zGs9HjCA
Forum|alt.badge.img+53
  • January 14, 2013
We have done something similar, albeit by taking a stylesheet and putting it into a csv file, appending some extra columns and then using a featuremerger to take that into fme.  Happy to share if you want to take a look.
We're quite a small authority so we don't have that much data going in, not sure how well if would handle larger areas.
clang
  • June 20, 2013
Does anyone have an FME workspace they are willing to provide me with to translate the OS Vector Map Local (vector dataset)? We already have a workspace and style sheet which I think was provided by the OS but the latest release of OS vector map is not translating all of the features for particular tiles? One of the tiles in question is SJ99NE.
Many thanks in advance,
Chris
