Number of parts in shape is incorrect for its geometry type
  • Mar 22, 2023 9:22 AM UTC
  • 5 replies
  • 532 views
ingalla
Forum|alt.badge.img+10
Hello
I am trying to write some polygon data from a csv file which contains the geometry data to an esri sde database, all the conversion is fine until i come to write the data when i get the error below. It says that the Number of parts in shape is incorrect for its geometry type. What does this actually mean. The data is building a polygon, which it does. I have added in a geometry filter to get the areas and polygons followed by a geometry coercer set to fme_polygon...
Any ideas how to fix this or what could be wrong??
Error while updating feature in the table/feature class 'OS_NGD_BLD_FTS_BUILDINGPART'. The error number from ArcObjects is: '-2147215922'. The error message from ArcObjects is: {Number of parts in shape is incorrect for its geometry type}
Storing feature(s) to FME feature store file `\\\\dnfme01\\FMEWorkbench\\Workspaces\\Ordnance Survey\\National Geospatial Database\\OS NGD Buildings Daily Update_log.ffs'
Feature Type: `OS_NGD_BLD_FTS_BUILDINGPART'
Attribute(32 bit real)       : `absoluteheightmaximum' has value `107.5'
Attribute(32 bit real)       : `absoluteheightminimum' has value `101.51'
Attribute(32 bit real)       : `absoluteheightroofbase' has value `104.53'
Attribute(string: windows-1252)  : `associatedstructure' is <null>
Attribute(string: windows-1252)  : `capturespecification' has value `Urban'
Attribute(string: windows-1252)  : `changetype' has value `New'
Attribute(64 bit unsigned integer) : `csv_line_number' has value `4610'
Attribute(32 bit unsigned integer) : `csv_number_of_fields' has value `39'
Attribute(32 bit unsigned integer) : `csv_total_number_of_columns' has value `40'
Attribute(string: windows-1252)  : `description' has value `Building'
Attribute(string: windows-1252)  : `description_evidencedate' has value `19940804'
Attribute(string: windows-1252)  : `description_source' has value `Ordnance Survey'
Attribute(string: windows-1252)  : `description_updatedate' has value `19940804'
Attribute(string: windows-1252)  : `firstdigitalcapturedate' has value `19940804'
Attribute(string: UTF-8)      : `fme_db_operation' has value `UPSERT'
Attribute(string: UTF-8)      : `fme_feature_type' has value `CSV'
Attribute(string: UTF-8)      : `fme_geometry' has value `fme_polygon'
Attribute(entangled: string: UTF-8): `fme_type' has value `fme_area'
     entangled to geodb_type
Attribute(64 bit integer)     : `geodb_oid' has value `1'
Attribute(string: UTF-8)      : `geodb_type' has value `geodb_polygon'
Attribute(64 bit real)       : `geometry_area' has value `95.421825'
Attribute(string: windows-1252)  : `geometry_evidencedate' has value `20160823'
Attribute(string: windows-1252)  : `geometry_source' has value `Ordnance Survey'
Attribute(string: windows-1252)  : `geometry_updatedate' has value `20180412'
Attribute(string: windows-1252)  : `height_evidencedate' has value `20220417'
Attribute(string: windows-1252)  : `height_source' has value `Ordnance Survey'
Attribute(string: windows-1252)  : `height_updatedate' has value `20220824'
Attribute(string: windows-1252)  : `heightconfidencelevel' has value `Not Assessed'
Attribute(32 bit unsigned integer) : `isobscured' has value `0'
Attribute(32 bit integer)     : `multi_reader_full_id' has value `1'
Attribute(32 bit integer)     : `multi_reader_id' has value `1'
Attribute(string: UTF-8)      : `multi_reader_keyword' has value `CSV2_1'
Attribute(string: UTF-8)      : `multi_reader_type' has value `CSV2'
Attribute(32 bit unsigned integer) : `multi_writer_id' has value `0'
Attribute(string: windows-1252)  : `osid' has value `ccddf186-e99b-46b5-b6fd-416b8aac0b84'
Attribute(string: windows-1252)  : `oslandcover_evidencedate' has value `19940804'
Attribute(string: windows-1252)  : `oslandcover_source' has value `Ordnance Survey'
Attribute(string: windows-1252)  : `oslandcover_updatedate' has value `19940804'
Attribute(string: windows-1252)  : `oslandcovertiera' has value `Constructed'
Attribute(string: windows-1252)  : `oslandcovertierb' has value `Building'
Attribute(string: windows-1252)  : `oslanduse_evidencedate' has value `19940804'
Attribute(string: windows-1252)  : `oslanduse_source' has value `Ordnance Survey'
Attribute(string: windows-1252)  : `oslanduse_updatedate' has value `19940804'
Attribute(string: windows-1252)  : `oslandusetiera' has value `Residential Accommodation'
Attribute(string: windows-1252)  : `oslandusetierb' has value `Private Residence'
Attribute(string: windows-1252)  : `physicallevel' has value `Surface Level'
Attribute(32 bit real)       : `relativeheightmaximum' has value `5.99'
Attribute(32 bit real)       : `relativeheightroofbase' has value `3.02'
Attribute(string: windows-1252)  : `theme' has value `Buildings'
Attribute(string: windows-1252)  : `toid' has value `osgb1000014460052'
Attribute(string: windows-1252)  : `versionavailablefromdate' has value `20220827000000+00:00'
Attribute(string: windows-1252)  : `versionavailabletodate' has value `20230321235959+00:00'
Attribute(string: windows-1252)  : `versiondate' has value `20220826'
Coordinate System: `EPSG:27700'
Geometry Type: IFMEPolygon
Boundary:
  Geometry Type: IFMELine
  Number of Coordinates: 4 -- Coordinate Dimension: 2
  (482389.1,144658.55)(482387.44103171496,144656.07998055348)(482387.441,144656.08)(482389.1,144658.55)
GEODATABASE_SDE writer: An error has occurred. Check the logfile above for details
Best answer by nielsgerrits
The geometry is a line going back and forth without an area, which is not valid in SDE for geometrytype polygon.
Also, the 2nd and 3rd coordinate are almost the same. In SDE coordinates are not floats but "fixed" coordinates on a grid. This means the coordinates are snapped to the same point, generating a duplicate consecutive point.
nielsgerrits
Forum|alt.badge.img+67
  • Mar 22, 2023 9:31 AM UTC
ingalla
  • Mar 22, 2023 9:33 AM UTC
That now makes sense, any idea on the best way of fixing this??
The second and third coordinates seem very close and, depending on your feature class tolerance, might end up collapsed into a single vertex in the database, rendering the polygon invalid.
See also here:
https://community.safe.com/s/question/0D54Q000080hffpSAA/error-message-when-writing-lines-to-sde-the-error-number-from-arcobjects-is-2147215922-the-error-message-from-arcobjects-is-number-of-parts-in-shape-is-incorrect-for-its-geometry-type
ingalla
  • Mar 22, 2023 9:40 AM UTC
See also here:
The tolerance is set to 0.0001
ingalla
  • Mar 22, 2023 9:50 AM UTC
Thanks both for your input, I have added in a area calculator, followed by a tester to find everything grater than the tolerance and it works fine...
