Archived
Change wording on tester/testfilter conditions
Related products:Transformers
The tester and testfilter conditions for empty, null, missing and has a value currently refer to attributes. E.g. "Attribute has a value". This can be confusing because they can also work on parameters. Maybe the wording should be changed?
