NeighborFinder: Try to get elevation but get this error: IFMELine was given an index beyond its current range
lau
Forum|alt.badge.img+3
Hello,
I am trying to get the elevation using a NeighborFinder. I get this error:
IFMELine was given an index beyond its current range (see workspace in attached)
And I get 'nan' for the elevation. Any idea why?
Best answer by markatsafe
@lau This does seem to be a defect in the NeighborFinder. When the point (Base) is past the end point of the line (candidate) then you'll see this error. We'll get this fixed.
gio
Forum|alt.badge.img+15
  • January 5, 2018
You do not have any z value on neither the line or the point.
(no z value does not mean that the elevation is zero, it means there is no such value)
You could add elevation at the creator(s) or use a 3d forcer to add a z value.
gio
  • January 5, 2018
btw nan = not a number
  • January 7, 2018
I think the error has been caused by a defect of the NeighborFinder. Hope someone from Safe to clarify this.
lau
  • January 8, 2018
Oups I have just seen that one of my creator creates a "line" with 0,0 ; 0,0 coordinates. This results from an old test. But the following VertexCreators create indeed a line with z values
lau
  • January 8, 2018
I found a workaround but indeed, it seems there is a bug with the "Take z From Candidate" functionality of the NeighborFinder.
I use a densifier to densify the vertex of the candidates. Then I used a chopper (1 vertex) to get points. I recorded the z in an attribute and use merge attribute in the NeighborFinder. Not efficient but effective :)
  • January 10, 2018
lau
  • January 11, 2018
Indeed. Thank you for the follow up!
lars_de_vries
Forum|alt.badge.img+10
This issue also counts for Measures. By the way the error is still present in build 18528
