My connection file works, but not if it's a parameter. I believe this should work, but it doesn't. It looks like a bug in FME. Is there a way to fix this?
I am using several FeatureReaders (ArcSDE) and they have a connection file that I paste in. I want this to be a parameter so that I do not have to update several readers when I want to change the connection file. When I create the parameter and try to run it then I get an error that says "Too many recursive macro substitutions". What is the best way to fix this? Thanks.
nielsgerrits
Forum|alt.badge.img+57
What kind of parameter do you use? Did you configure the FeatureReader first, then replaced the connectionfile with a parameter? This is what I do and it works, using a scripted python parameter. But you have to configure it first, run to check, then replace values with parameters.
  • November 7, 2020
I use a text parameter. The reader works if I do not use a parameter. I configured it first, then tried to replace the value with a parameter.
  • November 7, 2020
I have good news. I think I got it to work. When creating the parameter, I add the letter "a" at the end of the name of the parameter and the letter "b" at the end of the prompt. Now it works. I don't know why this works, but I'm just happy that it does.
I am now going to update the dozen other reader with these new parameters and see if I come across any issues.
hkingsbury
Forum|alt.badge.img+59
  • November 8, 2020
I've had this same issue , off the top of my head I believe I got around it by creating the parameter in the transformer.
Screenshot 2020-11-09 081151
  • November 9, 2020
I've tried that and it doesn't work. I had to add the extra "a" and "b" in the parameter definition to get it to work. Then I removed the "a" and the "b" and it failed again.screenshot
mtaftferguson
It seems like a combination of these tricks is what it took for me. Renaming the parameter didn't work, so I tried creating a new parameter from within the transformer. That also failed, but then when I pointed the reader back to the old renamed parameter, voila!
I have two FeatureReaders in the workspace that used the same parameter and they each needed the above-described fix applied separately.
Like the two comments with screenshots, I'm also reading an ArcSDE db.
Is this fixed in 2021/a known bug?
