MSWordStyler how to include picture in table?
  • March 6, 2019
  • 10 replies
  • 515 views
jdh
Forum|alt.badge.img+41
I would like create a MSWord document that includes a table that has 3 columns. The first two columns are just attributes, but the third should be a thumbnail image, whose path is stored in an attribute.
I can use the MSWordStyler to generate a table, I can also use it to add the pictures.
What I haven't been able to figure out is how to add the pictures in the 3rd column of the table.
arnovananrooij
Forum|alt.badge.img+5
I don't think this is possible in word with FME. It is possible in html with the html report generator using custom HTML:
https://knowledge.safe.com/questions/84748/conditional-html-report-formatting-and-table-conte.html
You can open HTML documents with word.
Forum|alt.badge.img+53
  • March 7, 2019
Do you need to avoid python?
jdh
  • March 8, 2019
No, python is fine.
What I'm hoping to avoid is falling down the rabbit hole of custom jsonSnippets/XML that @janb pioneered.
  • March 8, 2019
No, python is fine.
I have a workflow that creates the table in a word document with the image column populated with the imagepath, then after a featurewriter uses a pythoncaller to replace that text with the image specified by the path. It's on my machine at home, so I can share later.
jdh
  • March 11, 2019
@egomm I would love to see that workflow.
  • March 11, 2019
write_to_word_python.fmwt
It's never been used in anger, but was something I was experimenting with, but might give you some ideas.
jdh
  • March 11, 2019
Thanks, this gives me lots of ideas.
EDIT: docX is awesome, I've gone to creating the entire document in python, rather than have a dozen samplers and MSWordStylers to create all the necessary hierarchy.
oliviergayte
  • March 14, 2019
Thank you egomm.
Your script is great!
venu
  • April 3, 2022
No, python is fine.
can share again
andreaatsafe
Forum|alt.badge.img+17
No, python is fine.
Hi @venu​ ,
The comment above has been updated with the link to the workspace "write_to_word_python.fmwt" now.
-Andrea
