Measure distance between two lines at specific interval
  • February 17, 2017
  • 146 views
ingalla
Forum|alt.badge.img+10
Hi all
I have the edges of a road and want to be able to measure the distance between the two edges perpendicular to the left hand edge at a distance every 10 metres.
Any suggestions on how to complete this as I can not get my head around it.
Thanks in advance.
Best answer by jeroenstiers
Hi @ingalla
I would suggest to use the IterativeSnipper to generate a point every X distance for both lines and then use the NeighborFinder to find the closest point of the other line. The NeighborFinder also returns the distance to this point.
Forum|alt.badge.img+7
  • February 17, 2017
Hi @ingalla
  • February 17, 2017
I agree with @jeroenstiers. I'll just add that if you have a common ID on both road edges, I'd recommend using those as a Group By for the NeighborFinder. This will avoid a lot of problems in e.g. intersections.
  • February 17, 2017
jeroenstiers wrote:
Hi @ingalla
Agreed. I'll just add that if you have a common ID on both road edges, I'd recommend using those as a Group By for the NeighborFinder. This will avoid a lot of problems in e.g. intersections.
ingalla
  • February 17, 2017
jeroenstiers wrote:
Hi @ingalla
Thanks all for your comments / advice
