Make flow map with points
geo-x
Dear FME community.
I would like to make a flow map like in french "carte en oursin"
For do that, I've multiple group of points like this structure : One center with multiple destination for each group of points.
I tried to do that with this workbench :
Can you help me ?
Thank you.
Best answer by takashi
Hi @lalandexavier, I would use a CoordinateExtractor, a FeatureMerger and a VertexCreator. In addition, you can reverse the orientation of resulting lines with the Orientor if necessary.
lars_de_vries
Forum|alt.badge.img+10
Hi @lalandexavier,
I would use a NeighborFinder transformer and feed the destinations in the Base port and the Centre in the Candidate port. You can set the Id as GroupBy. Next you can add a VertexCreator with 'Insert Point At Index' using the _closest_candidate_x and _closest_candidate_y on index 0.
UPDATE: Using 'Insert Point At Index' and index 0 will cause an error. You can use 'Add Vertex' and if you would like to have the line running from the centre to the destination you could add an Orientor
  • May 16, 2018
geo-x
  • May 16, 2018
lars_de_vries wrote:
Hi @lalandexavier,
Thank you very much lars_de_vries both ideas with takashi are good !
geo-x
  • May 16, 2018
Thank you very much takashi that's work ! It's perfect
  • May 17, 2018
Upvoted for brilliant illustration of the problem :-)
