list of 3ds files in csv convert to sketchup
  • November 21, 2013
  • 47 views
rudy_v
I've posted this before, but it seems that after a few days nobody looks at it anymore to improve the answers.
https://safe.secure.force.com/AnswersQuestionDetail?id=906a0000000csa8AAA
I think questions should have a not solve button/tick, and then it can move up to the top of the list for review.
I have a list of 3ds models in a csv file. Each row in the csv file it also have xyz shift.
example:
m:\\data\\models2011\\CA000123.3ds, 33001.98, 58125.76, 12.54
m:\\data\\models2012\\CB000426.3ds, 33004.11, 58123.12, 12.94
m:\\data\\models2013\\NWB010426.3ds, 34014.11, 59193.34, 14.55
etc.
From previous answers it was suggested to use featurereader transformer + csv reader, but i cannot get it to work, because the dataset need to be a directory, but i want the dataset to be the row-column entry in the csv file
after reading the 3ds file, do offset for the row entry in csv file and write to sketchup.
read m:\\data\\models2011\\CA000123.3ds
off with  33001.98, 58125.76, 12.54 (= x,y,z) - 3ds models 0,0,0 origin
convert to sketchup
next line in csv file etc.
Rudy V
  • November 22, 2013
Hi again,
I think the WorkspaceRunner (suggested by David at first) can be used to do that. For example:
  Create new workspace, put a 3DS Reader. Source dataset parameter (3ds file path) will be published automatically. Define 3 published parameters to receive x / y / z offset values. Add an Offsetter transformer, link X / Y / Z Offset to corresponding published parameters. Add a SkechUp Writer to write models after offsetting.   Create second workspace, put a CSV Reader to read 3ds file path, xoffset, yoffset and zoffset line by line. Add a WorkspaceRunner, specify the first workspace file path to "FME Workspace"; pass 3ds file path and x / y / zoffset values to the first workspace through the corresponding published parameters.   Run the second workspace.
Takashi
