Lines connected?
  • April 5, 2017
  • 16 replies
  • 611 views
How can i check, if all my lines are ahve a connection to each other. I have a net of multilines and i want check that all lines have a connection to min. 1 neighborline. Case: Can the bus drive from point 'a' to the point 'b' without any interrupt way/lines.?
  • April 5, 2017
Try using the NetworkTopologyCalculator. You should only have a single value of "_network_id" on the output features. If you have more than one value, you have disconnected edges.
Be aware that a connection is defined by start/end-node only, meaning that two intersecting lines (like an X) doesn't necessarily mean that they are topologically connected.
You can use the TopologyBuilder to force connections at all intersections. Sometimes a Snapper can also be useful as a pre-processing tool if you have some tiny gaps in your line connections.
jdh
Forum|alt.badge.img+41
  • April 5, 2017
The NetworkTopologyCalculator will assign a unique ID to every set of connected lines. You can aggregate or use the statisticsCalculator on the _network_id to get a count per network.
Alternatively you can use the topologyBuilder to identify nodes that have only one connection (dangle nodes) and then identify the lines where both nodes are dangle to get isolated lines.
For the use case of driving a bus from point a to point b you can use the ShortestPathFinder, if a route is not possible it will come out of the NoPath port.
Forum|alt.badge.img+63
I used a different approach: SpatialFilter set to "Filter TOUCHES Candidate" and then input the lines as both Filter and Candidate.
  • April 5, 2017
Will that work for crossing lines that has no intersection node?
That's being passed as "failed", that makes sense I think (if it's not intersecting it's not connected to the network). If you do want to make those lines part of the network an Intersector will sort that out.
jdh
  • April 5, 2017
It will pass T intersections that are not properly noded, but will fail X intersection.
itay
Forum|alt.badge.img+19
  • April 5, 2017
Yet another approach would be to use the LIneJoiner, the join will take place only where segments are properly connecting.
  • April 5, 2017
What if you have more than 2 lines joining at a single node?
jdh
  • April 5, 2017
Could you explain how the Linejoiner would identify isolated segments?
gio
Forum|alt.badge.img+15
  • April 6, 2017
@jdh "Could you explain how the Linejoiner would identify isolated segments?"
Generate a list on the LineJoiner. List with 1 element (object itself) will have not joined to anyone.
Use ListElementCounter
jdh
  • April 6, 2017
Every segment connected at a node with 3 or more elements will also not have joined to anyone.
  • April 7, 2017
The snapper works nice in 50% case. So i want flag the lines and correct it self. How i can i transform the multilines/polylines to singlelines?
  • April 7, 2017
They not show lines who cross another line without a same node. Its important that i also this lines. Idea to complete the script?
  • April 7, 2017
Depends on what you mean by multilines, but if you want to split lines at intersections you can either use the TopologyBuilder or the Intersector.
There is also the Chopper, but I suspect that's not what you want?
  • April 7, 2017
Use the TopologyBuilder.
  • April 7, 2017
Topology Builder -> Network Builder ->
Control with ShortestPathFinder
Thx @all!
