AttributeExposer
  • August 11, 2025
  • 9 replies
  • 130 views
francisco_1988
Forum|alt.badge.img+5
How can I automatically add all attributes in AttributeExposer after AttributeTransposer without having to manually select each one?
Best answer by pratap
Hi ​@francisco_1988 ,
Attached a workbench for round about solution. Hope it helps.
Pratap
@francisco_1988
This workbench will be useful if you are looking in automatic approach.
Thank you
danilo_fme
Forum|alt.badge.img+52
  • August 11, 2025
Boa Tarde Francisco,
qual versão do FME você usa?
Obrigado.
francisco_1988
  • August 11, 2025
Obrigado.
Boa tarde danilo 2025
francisco_1988
  • August 11, 2025
Obrigado.
Boa tarde Danilo 2025
danilo_fme
  • August 11, 2025
Oi francisco,
Realizei um teste e vi que o transformer AttributeTransposer fornce os atributos sem precisar expor manualmente.
Você quer pode compartilhar seu workspace ?
danilo@solutial.com.br.
Obrigado
max_h
Forum|alt.badge.img+22
  • August 12, 2025
When you got feature caching activated, try this:
pratap
Forum|alt.badge.img+12
  • August 12, 2025
Pratap
francisco_1988
  • August 12, 2025
This approach works dynamically. For example, when reading multiple shapefiles, can I be certain that, for each execution of the workflow for a shapefile, the cache will be used correctly?
max_h
  • August 13, 2025
Sadly no, this would be a manual approach, check this topics for a dynamically solution:
https://knowledge.safe.com/questions/32483/dynamic-attributes-in-custom-transformer.html
Dynamically expose attributes | Community
Hope those help in your case!
pratap
  • August 13, 2025
Pratap
@francisco_1988
Thank you
