Line on Line Attributes
  • March 27, 2019
  • 6 views
I cannot figure out the correct transformer for this, what i thought would be, simple solution.
I have two spatially identical line features. One, is broken into a lot of segments. The other is broken into fewer segments.
I need to merge the attributes from one line to the other based on where they are spatially. I need my output to be the line broken into many segments, but absorbing the attributes of the fewer segment line.
Forum|alt.badge.img+40
  • March 27, 2019
Line on Line overlayer, with accumulation mode set to merge attributes - you may need to apply a tolerance to get the output you want
