Left/Right side of lines
  • Jun 21, 2019 1:18 PM UTC
  • 460 views
Hello FME users,
I have a set of lines that make up a polygon. I need to determine which side(left or right) of the line is "looking" outside of the polygon.
Lines are not oriented the same, end point of one is not always a start point of next line and so on.
LeftRightSpatialCalculator can't do the job because I don't have anything to Candidate.
Thank you in advance.
Milos
erik_jan
Forum|alt.badge.img+26
  • Jun 21, 2019 1:32 PM UTC
Create the polygons by using the AreaBuilder.
Then use the LeftRightCalculator with line as Base and polygons as Candidate.
This should show you if a polygon is left or right from the line.
  • Jun 24, 2019 7:45 AM UTC
This doesn't work for me. It gives me only polygon as an output and in feature information relative position as undefined for every line.
  • Jun 25, 2019 10:09 AM UTC
I had an idea how to solve this but i don't know is it valid and i had some additional problems.
My idea is to build polygon from lines, use Bufferer with small - buffer zone then use Chopper to decompose new polygon then use LeftRightSpatialCalculator to determine the side.
New problems are:
-I lost id of lines because of AreaBuilder.
-I gained extra line where angle is close to 360.
As a final result i need to have informations for only input lines.
I have uploaded my workspace and some simple test data.
example.fmw
test.zip
