Join 2 columns
  • Jan 5, 2017 2:06 PM UTC
  • 6 replies
  • 543 views
Hello All,
I have 2 columns that I need to merge into one. Columns are different attributes of a single feature class.
If Address 1 has populated field, then they are accepted. If Address 1 is null, then Address 2 is checked and information from that column will be copied to Address 1. If both columns are populated, Address 1 is accepted.
Any ideas of how I would do that? Any help would be appreciated. Thanks
Best answer by ebygomm
An attributecreator with a conditional value can be used here. If Address1 has a value do nothing, otherwise make Address1 equal Address2
Forum|alt.badge.img+54
  • Jan 5, 2017 2:09 PM UTC
Thanks for that suggestion. Can you elaborate a bit more please. I cannot find much help on using AttributeCreator with conditions
Forum|alt.badge.img+7
Hi @fariyafarhad
You can use an AttributeCreator and create a new attribute with the name 'Address1'. This new attribute will overwrite the old one. As value, you choose the option 'Conditional Value' which opens a new window in which you can enter a Test condition and an Output value.
TEST: If Address1 has a value, OUTPUT: Address1
ELSE OUTPUT: Address2
If something is not clear, I will be happy to help!
Good luck!
Thanks egomm, I just learned the use of conditions within attributecreator :D
Hi @fariyafarhad
Good luck!
Thank you for the answer @jeroenstiers!
  • Jan 5, 2017 3:09 PM UTC
Another option is to use the NullAttributeMapper, I find it slightly easier to read when reopening a workspace later on as you don't have to click through 2 dialogs to see what's going on:
