Issue with FindString() to match "101" in "101,102"
mzuer
Forum|alt.badge.img+5
Dear All,
Here is my issue with the FindString() function :
I have the following string stored in user parameter value_to_test = "101,102" ; the attribute "ProgNum" contains values that range from 100-900 and I want to set a new attribute "FoundNum" to be = "true" when "ProgNum" is one the (comma-separated) values of value_to_test.
As FindString(string,strToFind) should return the index in string that matches strToFind , I've tried the following expression :
@FindString($(value_to_test),@Value(ProgNum))
I have also tried the FindStringRegularExpression
@FindRegularExpression($(value_to_test),@Value(ProgNum))
None of the them is working ! Quite despaired I've also tried to revert $(value_to_test) and @Value(ProgNum) in the function call, but it does not work better...
Does anyone have an explanation what it is not working and what I am doing wrong ??
Thanks in advance
NB : I know that I could work with AttributeSplitter etc. but I would like to know why the FindString and FindRegularExpression functions are not working here
Best answer by geomancer
The problem is that value_to_test contains comma's. When you replace these with spaces, @FindString works as expected.
If you want to work with comma's in value_to_test, you can use a Conditional Value in the AttributeManager.
Conditional_Value_3Alternatively, you can use a StringSearcher.
  • June 30, 2023
Try inserting a ParameterFetcher to get $(value_to_test) into an attribute and use that in FindString() rather than the parameter reference.
geomancer
Forum|alt.badge.img+56
  • June 30, 2023
  • June 30, 2023
Good catch @geomancer​ , I didn't see that at first. It's then possible to enclose the reference with double quotes, e.g.
@FindString("$(value_to_test)","@Value(ProgNum)")
Unless value_to_test or ProgNum contains double quotes, of course...
mzuer
  • June 30, 2023
thanks a lot @geomancer and @david_r !
Definitely, I'll never get used to FME's weird under-the-hood behavior and its implicit and unexpected feature type handling/conversion...
