Is there a way to trick (or configure) the AffineWarper into non blocking?
rwhittington
It seems to me that once the Control vectors are sent to the AffineWarper that a single Affine transform could be calculated and applied to all Observed Features as they come through.
Best answer by fmelizard
Sounds like we need a "Control Vectors Come First" mode on that baby. Then we could do as Reed would like. I'll post an idea.
Hi @rwhittington,
Is the main concern the performance of the AffineWarper?
rwhittington
  • August 1, 2017
hi Annabelle, performance. Yes. It seems like it should not need to block if all Control vectors are supplied before Observed features. @DaveAtSafe gave me a tip to use the 3DAffineWarper. So will try that. Thanks for the help.
fmelizard
Forum|alt.badge.img+20
  • August 2, 2017
fmelizard
  • August 2, 2017
Here's the idea: https://knowledge.safe.com/idea/49378/affinewarper-add-control-vectors-come-first-option.html -- go vote! And/or clarify what I've written there. Thanks!
rwhittington
  • August 2, 2017
Thanks Dale.
