Is there a way of preventing the SurfaceDraper from creating a surface model unless it receives at least one DrapeFeature
  • June 9, 2021
  • 34 views
btl
Forum|alt.badge.img+3
This is my workspace, it adds elevation to lake polygons and river lines from a DEM. Lakes are calculated by clipping the raster and getting median elevation, meanwhile river lines are draped onto a surface.
Most of the time my data does not contain any lines, but the SurfaceDraper still creates a surface, which can take a while - is there a way to improve performance by preventing the SurfaceDraper from doing anything unless it receives at least one DrapeFeature?screenshot
@btl​  You need to link the two pipelines in some way and the add a Tester to block the DEM.
  • VariableSetter & VariableRetreiver can be used to link pipelines. Proved you can control the order of the inputs (make sure your line reader is the first reader in the navigator)
  • There is a NoFeatureTester on the FME HUB. If there are no features, then a single feature is output on the No Input port . Use the NoFeatureTester on the lines. Join the NoInput to your DEM (FeatureJoiner) and then if the join fails, don't pass those features.
Something like that...
