In a same dataset I have two columns that I want in a same column. How can I do that ? Thanks
danilo_fme
Forum|alt.badge.img+51
  • August 9, 2022
Hi @lachichi_farah​
You can configure it including the Writer file.
Please, could you share a example of your dataset?
Thanks in Advance,
Danilo
Isn't there any transformer for that ?
Here a dataset for example, thanks
I would like "result 1" and "result2" in a same column
@lachichi_farah​ Thanks for including the example dataset. Can you give a small example of the results you'd like to see? Do you want the sum(result1,result2) , do you want them concatenated result1,result2?
