I would like to copy/duplicate readers between workspaces, but can't find a straightforward way to do so.
  • August 13, 2021
  • 112 views
jmcarthur
I have a workspace that extracts users and attributes from Active Directory, at the OU level. I want to take this workspace and create a custom transformer as part of a larger workflow. Last time I copied these LDAP readers it completely broke everything and I had to fix them one-by-one.
Is there any way to import a workspace as a custom transformer? This is just reading a bunch of LDAP data and spitting out a CSV.
*Edited to reflect I'm trying to export/reuse connections, rather than transformers.
virtualcitymatt
Forum|alt.badge.img+43
Hmm, copy and paste should just work. Strange that it isn't (I haven't tried the LDAP reader).
To have a reader in a CustomTransformer you need to have the reader defined in a FeatureReader.
When you say that copy and paste broke the reader what happened?​
