I have many polyline Z features in the same feature class. I have modified them in such a way they are located at their own standard depth, relative to the surface level. How can I connect the last vertex at the same depth of connecting lines?
  • Oct 25, 2022 2:19 PM UTC
  • 53 views
I would like to modifiy the last vertex of each line feature, if the lines intersect, to copy the depth so that also the connection is made in Z-coordinates. Based on an attribute field there should be determined if the Z-value should be copied or overwritten of it's connecting neighbour.
f.kemminje
Forum|alt.badge.img+11
  • Nov 3, 2022 12:54 PM UTC
use coordinate extractor transformer, change the z value, re create geometry using vertex creator.
Negative index positions indicate position relative to the last vertex, where -1 is the last, -2 is second-to-last, and so on.
tomfriedl
Forum|alt.badge.img+14
  • Nov 3, 2022 5:24 PM UTC
To replace z-value of the last point:
replace_point
