I have a table with start and end x/y and need to create line for each. I created vertexes but no line is produced. How do I create a line for each coordinate pair?
  • Jun 1, 2023 11:48 AM UTC
  • 7 replies
  • 80 views
gcarmich
Participant
nielsgerrits
Forum|alt.badge.img+67
Use 2 VertexCreators and add them in serie. In the first one create a point from begin xy, in the second one, add a point from end xy.
geomancer
Forum|alt.badge.img+71
  • Jun 1, 2023 12:40 PM UTC
Adding to that: probably VertexCreator_5 needs to be in mode "Replace with point".
gcarmich
Participant
  • Participant
  • Jun 1, 2023 1:11 PM UTC
I have tried both those approaches. The first VertexCreator creates a point on the map but the second VertexCreator (as Add Point) seems to remove all geographic entities.
geomancer
  • Jun 1, 2023 1:43 PM UTC
Strange. See the attached example.
VertexCreators.pngNote that in your data there will be (at least) 304 features with start_X = end_X and start_Y = end_Y. I got rid of those in the TestFilter, but the presence of these features should not be the source of your problem.
gcarmich
Participant
  • Participant
  • Jun 1, 2023 2:45 PM UTC
Thanks. Your workflow works as expected.
I noticed that my CreateVertex has an extra parameter under advanced that yours does not - "Closed Line Handling" I wonder why they are different and if that could be the source of the issue?:
geomancer
  • Jun 1, 2023 2:54 PM UTC
I'm still using version 2020.0, where the VertexCreator has fewer settings. This should not be the source of your problems though.
gcarmich
Participant
  • Participant
  • Jun 1, 2023 3:51 PM UTC
I exported the table and created a new workflow with a reader for the table and two vertexcreators. This process was sucessful but it still does not work in the larger/original workflow. Seems to be a bug? I'll see if I can report it.
