In one case, I am getting a random problem with Esri Geodatabase:
12017-03-16 12:10:36| 2.1| 0.0|ERROR |Could not open the Enterprise Geodatabase. The error number from ArcObjects is: '-2147155644'. The error message from ArcObjects is: {Cannot connect to database because the database client software failed to load. Be sure the database client software is installed and configured correctly.}In another case I am having a random problem with Oracle:
12017-03-15 19:48:48| 248.5| 0.2|ERROR |Execution of statement `INSERT INTO "WELL_HELLO"."TABLE" ( "PKEY_HELLO",.....) VALUES ( :"PKEY_HELLO",.....)' did not succeed; error was `ORA-03135: connection lost contact Process ID: 12345 Session ID: 4321 Serial number: 98765'. (serverType=`ORACLE8I', serverName=`someserver', userName=`SOMEUSER', password=`***', dbname=`')2These workspaces are run on FME Server. How can I figure out the problem?
