I can't get opencv to work at all
  • October 6, 2021
  • 40 views
michiedem
Forum|alt.badge.img+7
I want to try openCV, but I get completely stuck with no real error message at all. I tried a lot of different approaches, but even the simplest doesn't work whatsoever.
Workflow for the simplest:
Use the openCV comandline to mark positive samples and generate an annotation file. To make it as simple as possible, I tried 1 positive sample, resulting in this annotations file:
F:\\temp\\opencv\\positives\\0.png 1 45 35 38 63
Next I made a folder containing negatives with 20 negatives (tried .png and.tif)
Next up is the samplepreparer:
negatives: use existing (tred overwrite too)
positives:
number of samples: 1
width/hight 200 and 200 (tried numorous different values)
I allocate a negatives and vec file location and that's it. No spaces in anny of the folder structures.
I get rejected features.
Storing feature(s) to FME feature store file `F:\\fmetemp\\wb-cache--PkosFd\\Main_RasterObjectDetectorSamplePrepar -1 19 fo 1 _lt_REJECTED_gt_ 0 9db0cf751f86d66944dfbb4c75f54d358bd7f17d.ffsupdating'
Creator_CREATED_-1_20_Player (RecorderFactory): Played back 1 feature(s) from file `F:\\fmetemp\\wb-cache--PkosFd\\Main_Creator -1 15 fo 0 CREATED 0 11b5656fcc71b159fce42912dc7f3f1439c50cdd.ffs'
I tried the samplegenerator in an even simpler way:
1 negative image (.jpg)
of course 1 postive (.jpg)
DIfferent width and height settings. different numbers of output. Tried it all and it all results in rejected without an error message,
michiedem
  • October 6, 2021
for future reference: it tuns out opencv does not like absolute paths as you can aslo read here: https://community.safe.com/s/question/0D54Q000080hfHhSAI/rasterobjectdetector-sample-preparer
The new problem is that the output just doesn't make sense at all, not even with a much higher amount of positives and negatives. I use cars on aereal photo's as possitives. The results out of OpenCV are much larger (city blocks)
