HTTP Caller - get info from _website_url for ESRI portal layer
  • Dec 11, 2024 9:40 AM UTC
  • 5 replies
  • 182 views
marta.podsiad
Forum|alt.badge.img+12
I am struggling to read the content of a layer published to ESRI portal. I have a  _website_url
https://gis-eu.xxx.com/arcgis/rest/services/LayerTest_Pt_01/FeatureServer/0
for ESRI portal layer.
For example I need to get Item Id
HTTP_Caller does not get this info in _response_body
Best answer by ebygomm
The request just needs to the ?f=pjson appending at the end, e.g.
….LayerTest_Pt_01/FeatureServer/0?f=pjson
marta.podsiad
  • Dec 11, 2024 10:07 AM UTC
I have managed to make it work. However, how can I get the Service Item Id: from the sting
<b>Display Field:</b> objectid<br/><br/>
<b>Type: </b> Feature Layer<br/><br/>
<b>Geometry Type:</b> esriGeometryPoint<br/><br/>
<b>Description: </b> <br/><br/>
<b>Service Item Id: </b> 4c0f943fb60a4a369104f33d1ad2af4f<br/><br/>
Forum|alt.badge.img+54
  • Dec 11, 2024 11:50 AM UTC
It’s going to be easier to retrieve the information you need if you get the initial call to return json so
?f=pjson
on the end of your request
Then a jsonextractor
marta.podsiad
How can I get this info in json format
  • Dec 11, 2024 3:04 PM UTC
marta.podsiad
Such an easy fix. Thank you very much!!!
