Writing solids
  • Jun 20, 2025 2:46 PM UTC
  • 140 views
fdw
Forum|alt.badge.img+7
I wonder if anyone knows a knows what would be a good format to write out solid geometry. I have worked with filegeodatabase but that is multipatch. I need spatial indexing to be able to use a spatial intersect with a feature reader. So a big dataset with solids where we often only need a few of.
The multipatch feature class (FGDB) kind of works but then I need a solidbuilder and that takes a lot of time.
Thank you!
Best answer by itsmatt
​@david_r yes I guess that will problaby work for our use case. Is there any other format you could think of that supports this?
FFS does seem like a good option. But I would also like to mention that a solid builder isn’t always required. You can also use a GeometryCoercer to coerce a CompositeSurface into a Brep and it’s much faster.
Another option would be storing the Solid Geometry and an attribute (e.g., GeoemtryExtractor)? Then in your workflow replace the Solid with a 2D representation (Polygon) which can be used as a spatial query.
Other options for Solids include CityJSON and CityGML, however, you can’t work with a spatial index there. But there is the 3DCityDB which is the database version of CityGML (PostGIS).
  • Jun 20, 2025 3:59 PM UTC
If you’re only ever going to read it back into FME (guess based on the mention of the FeatureReader), you could look into using FMEs own native format, FFS:
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/ffs/ffs.htm
fdw
  • Jun 23, 2025 11:24 AM UTC
itsmatt
Forum|alt.badge.img+48
  • Jun 23, 2025 12:02 PM UTC
