How to translate mesh in local coordinates into a rectangle region in EPSG:4326?
  • Mar 26, 2021 9:05 AM UTC
  • 121 views
I want to translate my fbx mesh in local coordinates to a rectangle region in EPSG:4326. The mesh XY bounds has the same ratio as the rectangle region. I tried reprojecting the mesh from XY-M to EPSG:4326 and apply an offset to shift it to the rectangle center, but the reprojection doesn't seem to change the mesh vertex coordinates. How can I translate the fbx mesh in arbitrary coordinates to a point (or the origin) in EPSG:4326 coordinate system?
daveatsafe
Forum|alt.badge.img+24
  • Mar 30, 2021 3:29 PM UTC
Hi @meancat​ ,
If you know the lat/long coordinates of the origin the mesh, you can use the LocalCoordinateSystemSetter to create a custom local coordinate system on it. The mesh can now be reprojected to any other coordinate system with the CsmapReprojector or PROJReprojector.
The XY-M coordinate system isn't quite the same as a local coordinate system - it basically tells FME that you know the data is in meters, but you don't know where it is.
  • Mar 31, 2021 9:05 AM UTC
Thanks Dave, I realized that the Scaler and Offsetter transformers are not applying their transformations to the mesh vertex coordinates, but rather modifying the transformation matrix attribute. How can I transform mesh coordinates (i.e. coordinates in the IFMEMesh's vertex pool)?
